A stacking protocol version mismatch has been detected between the local and remote nodes. It means that the stacking protocol running on the remote node is not compatible with the stacking protocol running on the local note. Thus the stack topology could not be formed between these nodes and therefore software upgrade is not possible between these nodes.
Upgrade the incompatible node with the version of EXOS that is running on the node that reported this message.
Warning
Stacking protocol version mismatch detected on the node connected to node %mac% stack port %port%. Software upgrade is not possible between these nodes.
| Name | Type |
| mac | MAC |
| port | uInt |
